Simple I converted several MKV's to MP4's using XMedia Recode. I just remuxed them by copying the tracks, and they won't play on my Xbox 360. It's a standard H.264/AAC MP4, not sure why it won't play. Here's the MediaInfo, please and thanks!
Code:General Complete name : *REMOVED FOR PRIVACY* Format : MPEG-4 Format profile : Base Media Codec ID : isom File size : 207 MiB Duration : 25mn 25s Overall bit rate : 1 139 Kbps Encoded date : UTC 2016-03-17 21:41:44 Tagged date : UTC 2016-03-17 21:41:44 Writing application : Lavf57.26.100 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 8 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 25mn 25s Bit rate : 948 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Frame rate : 23.976 fps Minimum frame rate : 23.564 fps Maximum frame rate : 24.390 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.043 Stream size : 172 MiB (83%) Writing library : x264 core 148 r2597 e86f3a1 Encoding settings : cabac=1 / ref=8 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=948 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=62500 / vbv_bufsize=78125 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00 Encoded date : UTC 2016-03-17 21:41:44 Tagged date : UTC 2016-03-17 21:41:44 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : HE-AAC / LC Codec ID : 40 Duration : 25mn 25s Bit rate mode : Constant Bit rate : 186 Kbps Channel(s) : 2 channels Channel(s)_Original : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 KHz / 24.0 KHz Compression mode : Lossy Stream size : 33.9 MiB (16%) Language : English Encoded date : UTC 2016-03-17 21:41:44 Tagged date : UTC 2016-03-17 21:41:44
Results 1 to 11 of 11
Could be reference frames, variable frame rate, perhaps others. Try comparing to a known good file that plays.
It has a variable frame rate which a lot of players won't accept,what you need to do is get the original mkv and open it in tsmuxergui and change the frame rate from 9000 to 2400/1001 and save as file.ts.Then open the ts file with mkvmerge and remux as mkv,then load the remuxed mkv into mp4box save as mp4.
No need to re-encode the mkv into mp4,all the steps i've type just repackages the video.I think,therefore i am a hamster. -
I've tried other files with reference frames of 3, 5, & 8, they played just fine. Not sure if I have another video with variable frame rate. I've compared it to another file that worked, tried testing any differences I though would matter, to no avail. Anything else specific you think could make a difference?
I didn't re-encode, just used XMedia Recode to Remux them, no re-encoding.
Thank you both for the fast replies! -
My sony blu-ray player will display videos with variable frame rates but my sisters lg blu-ray player just says the file is corrupted.
As a long time Xbox 360 user, I've come to understand its constraints for video playback. The video looks fine, even with the variable frame rate which never caused a problem for me. And it's in an MP4 which is good.It's a standard H.264/AAC MP4, not sure why it won't play.
The audio on the other hand is probably your problem. Firstly the HE-AAC, which I've never know Xbox360 to like. Secondly it looks like the audio may be 5.1 Surround, which Xbox 360 also does not like.
You need to use basic AAC-LC Stereo if you want your Xbox to play it. -
The video also has a stereo audio.
here's the supported audio & video formats for xbox 360 - http://support.xbox.com/en-US/xbox-360/console/audio-video-playback-faq
The bitrate say 186 kbps for 2 channels,the original channel was 6.
No, "Channel(s)_Original" is the actual number of channels in the AAC bitstream. "Channel(s)" is just the (in this case incorrect) number written in the mp4 container.
Why won't the Xbox 360 playback .mp4 video
By smitbret in forum Media Center PC / MediaCentersReplies: 20Last Post: 9th Feb 2017, 08:52 -
MKV to MP4 Variable Frame Rate - Xbox 360
By admiralspeedy in forum Video ConversionReplies: 7Last Post: 21st Mar 2013, 13:00 -
Mux or Encode MP4 to xbox 360
By Shade_21 in forum Newbie / General discussionsReplies: 8Last Post: 26th Aug 2012, 15:25 -
MP4 Issue On Xbox 360 (please Help!)
By Cornholio77 in forum Media Center PC / MediaCentersReplies: 9Last Post: 31st Dec 2011, 23:09 -
Problem: Playing HD h.264 file on Xbox 360
By TOMillr in forum Media Center PC / MediaCentersReplies: 1Last Post: 5th Apr 2011, 08:04
